Item: Standard GTR Front bar / Fibreglass GTR Front bar to fit GTS-T
Age: meh
Condition: Good
Price: Depends on what it is and the condition.
To Fit: (What car) R32
Contact: 0402 198 170 - sms during bus hours pls
Comments: hook me up! need a bar for rwc.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
