Ok everyone has be telling me for ages that my turbo can't be stock for the power it makes.
I just recently heard some strange noises from the turbo area and decided to pull it off. The rear housing is standard as is the turbine(48mm ceramic). The compressor is 49.5mm top and 64mm lower. I compared it to a VG30bb and the trim on the blades is also different. The compressor cover is also a 45V2 VG30bb unit with slight machining.
Can anyone tell me if the 45V4 rb25 compressor is the same dimentions as the Vg30 or More like mine???? meggala???
Would be good to work out if it has been modified, seems to work very well. If it does turn out to be non standard, I would think a VG30 comp cover and high flow wheel with the same trim would be a very cheap upgrade.
full boost by 2500 to 3000
218rwkw @1bar
225rwkw @1.1bar
I am having it rebuild with a larger VG30 exhaust housing. I will post the result next week after it's finished and dyno'd.
the car came over with a chipped computer and massive fuel filter-go figure. maybe it had a package deal done, I have seen the advertised by tuning shops in japan.
https://www.sau.com.au/forums/topic/19304-12sec-stock-turbo-secret-revealed/
Boosted,
What other mods have you done my goal is around 230Kw at the wheels dont wanna go too far past this as i still want a daily driver and something reliable...
Just wanna know what i need to get it to that kinda power.. slowlu buiding up.. i'll prolly get there in about 10 years though.
paydro,
the kit cost me $400 out of the local trading post. Normally around $1400.
The car will run a high 12 without the Nitrous. Tyres permitting a low 12 with the switch flicked. after I set it up on 50hp a 100hp jet goes in and 11's are on.
sounds very cool to me.
im in the process of upgrading my standard r33 for 12 sec passes but i dont want to use nos yet i want to keep the internals stock as well but planning on using a apexi power fc and avcr boost controller with an obvious turbo upgrade or larger internals.
theres a few other things ive got inmind but ill se how this goes first.
but nos definatley sounds like fun.
p.s. good pick up on the nos
bump
drivebai, performance wise the car has a zaust, filter, cat in pipe, HKS EVC, Power FC, Cold air intake, Greddy front mount intercooler, oil/air seperator, octane booster for 12sec run and a HKS solid centre twin plate clutch. Also running 255 17" on the back.
bump
Boostd thanks man.. i have all those mods except for about 90% of them hehehe so it looks like i will need Power FC, front mount oil/air separator, and hi flow turbo.. basically i need all the expensive stuff... yeah i got 255 17" on the back as well man... I wish you were in Sydney dude.. cos you are pretty much where i am aiming for round 230rwkw... would have been good if you could have taken me for a spin in your car.. so i can see what 230rwkw feels like and compare the differences between my fairly stock crappy car!!!. then i would have more incentive to save.. hehehe.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
