Guest wilco
Yar I got all the details, the witness etc, gonna make them pay up :P
The problem really is the back suspension took a big knock when they hit me in the side, moved the whole back end over to the right a few inches, going in for a check-up by the insurance company Wednesday.
What happened with you?
https://www.sau.com.au/forums/topic/19313-cruise/#findComment-418643
Guest wilco
Some guy was driving, he looked stoned or pissed or something but the cops didn't want to attend the scene. Female passenger who owned the car and did all the talking furthering my thoughts the driver was on something.
I would say there is a bit more than 2k on this one, they have written down a lot of stuff to replace, will see the quote on Wednesday when I head back down there.
Freakin retards everywhere. Two months ago I was tail ended at a railway crossing by some fool when I slowed down for the car in front of me to cross it, I was almost stopped and had been for about 2 or 3 seconds and the clown slammed the brakes and slid into my back end, just one wide scratch which polished out, but still - retard.
https://www.sau.com.au/forums/topic/19313-cruise/#findComment-418709
Guest wilco
Lots of women I know admit to being terrible drivers, my own girlfriend told me she is one of the worst drivers she knows and said if she were cleaned up n the side as I was yesterday that she would have turned right (into oncoming traffic) to try and get away from the other car!!
:P
I think good female drivers are an endangered species, but that is certainly not to say a good % of male drivers are shit house too.
I shall stop this dicussion now :)
https://www.sau.com.au/forums/topic/19313-cruise/#findComment-418799
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
