A littl while back I blew the ceramic turbos, and had them rebuilt hi flowed with steel wheels. After putting it all back together, it also seems that the engine has suffered a bit from the turbos blowing up - it's down on compression in cylinders 2 and 3 and blowing a bit of smoke (but only on gear changes of whem blow off valves open)
Anyhow, I haven't had the time or cash to pull the engine down for what I understand will be a rebuild at some point in time.
What I do want to know is - and this may seem a stupid question but bear with me, my old man has organised a drag meet/speed trial in my small home country town - he wants as many cars out there as he can, and would like me to run mine, even if it's just a couple of half hearted runs - but lets face it, does anyone ever go half hearted?
What is the chances that I'm gonna do some real damage - like dropping a bearing, or putting some crap through my new turbos?
https://www.sau.com.au/forums/topic/193210-am-i-gonna-kill-my-turbos/
From the soudn of things you will do some serious damage!
If your engine is on the edge then flogging it will more than likely make it go pop. If the turbos are recently rebuilt, then they should be ok. Either way its rebuild time for you. :yes:
Edited by stolen_s15
find out why its low on compression. do a leak down test and a compression test. if its just worn rings then go for it hammer the crap outta it till it dies i say :P
post your compression details
Yeah, I've got the results written down at home, I'll post em up tonight, but just from memory, I think all cylinders were about 145-150, and cylinders 2 and 3 were down by about 10.
down by 10psi isnt a real issue, its not perfect but if the biggest variance you have is 10psi between the highest reading and lowest reading piston thats should be ok.
How many kms has the motor done? What oil are you running? If the motor is just a little tired because of high kms, hence the oil burning, i would still beat up on it.
Change the oil and filter before you go, and have some fun i would say.
I just found the comp results:
All cylinders were 145 - 150 like I said, but 2 and 3 were both at 125.
Not sure on how many kms engine has done, it came from a half cut that also had and aftermarket dash, which had 25, 000 on it. It's an R33 engine though.
Can't recall the specific oil, it's pennzoil I believe, certainly not cheapie stuff.
Sorry that I'm a bit vague, the car is stored at my folks place up country - no parking at my place :angry:
are you running twin turbos on a rb25??
well if the lowest reading is 125 then thats a 25psi difference and thats a tad too much
try and do a leak down test and see where its leaking, ie rings, headgasket, valves etc
if you dont really have the cash to fix it, dont push it then cause by the sounds of things the engine has hard a rough life and is on its last legs. In saying that if it was me i would still be booting the shit out of it, you gotta teach these engines a lesson... :D
if you dont really have the cash to fix it, dont push it then cause by the sounds of things the engine has hard a rough life and is on its last legs. In saying that if it was me i would still be booting the shit out of it, you gotta teach these engines a lesson... :)
It's an rb26, with a set of slides hi-flows. I haven't had a leak down test done, so that might be the next step.
I'm def keen to give it a flogging, and I'm prepared to cop some ring/piston/bore damage, but not so keen on dropping a bearing or valve, or putting some big chunks through the turbos.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
