Hi there..
im in sydney, but can COD at buyer exspence.
1) HKS ssqv bov adaptor for skyline (brand new) SOLD
2) Nismo Racing Radiator Cap (Brand new) fit most nissan $60(firm)
2) Nismo Oil Flller cap (Brand New) fit most nissan $150 (firm)
any question feel free to contact me on [email protected]
thx
https://www.sau.com.au/forums/topic/19341-nismo-and-hks-stuff/
  • 5 weeks later...
