nothing special happened to me, the usual loss of 4 points, 1500$ fine.. and an orange sticker slapped on my car to indicate that my car must be towed to have it inspected.
As you can see, should be fine.
any news on the man charged for doing 190 Km/h on Tuggeranong Parkway?
would be rather interesting to know what sort of car he drives.
Its was me i was in a R33 Gts t and i wont be getting a fine i will be going to jail they will try to make an example out of me
Edited by R33Gtst Driver
I havent seen any details about the car involved but if you get caught doing a speed heavily exceeding the maximum fine then you go to court to have a judge decide what to do with you. With a good lawyer you could get away with 1-2 years ban and a return on probational restricted license. With a bad lawyer or no lawyer you could get 5 year ban and have to reapply for your license.
If its in the news then most judges will want to be as tough as possible.
Cool, so we got a Skyline, and Flindstones car and a RS...?
Is anyone actually serious?
Would be interesting to know what happens to one, if they get caught doing double the limit
lol I dont care if you belive me or not if dont go jail ill tell you what i get for it if you dont here from me you know what happened
im not telling you guys anything else in case they try to use this against me in court after its all dealt with and if im not in jail ill tell you the whole story i still havent seen what they said in the paper just my mates have told me that im in there and it was in prime news the other night im pretty sure ill be going to jail for this they will make an example out of me and try to use this to bring in the nsw law about crushing cars into the act
I'm aware what they can do, just interested in what they really do.
Kappa, if it was you, good luck man, get a good lawyer. Rem, don't clench down too hard in the slammer, i hear it just makes it bleed more :P
thanks im interested in what will happen too :(
A mate of mines younger brother set the NSW speed record for a L-plater earlier this year. 200+km in a 100 zone... He cant get his licence for a few years and had to go to court, massive fine aswell
bad news son,
i was hoping it was a commonwhore driver lol i had a run in with one the other day. Fat C*&$ swore at me out his window so i pulled over and approched him and the two girls he was with ready to bang some sence into his head.
When i asked him what he said he replied with "nothing" and acted like the coward he is, so i thought well the girls probly think nothing of him now for being a coward so ill let it slide.
bad news son,
HAHAHAHAHA! I think that's 2 times you've gotten out of the car. I should tag along with you one weekend. :ermm:
Does anyone know what happened to the guy who got caught doing 200+ in his Bentley Continental GT at Collector a few years back? I remember reading the NSW police commissioner when to a Bentley dealership and sat in the car and commented that 'I can see how he can't tell how fast he is going in it because its so quite when its cruising' :P
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
