Hi Guys
This is my first nissan ive ever bought, i swapped my 94 Mitsubishi GTO(Which had some work done to it), and before that i had a MY00 WRX...
now i decided to go the 95 Nissan Skyline GTST, and at the moment its completely stock here are the details:
KMs:155,000 km's
exhaust: 3inch mendrel bent turbo back
Turbosmart bov
POD air filter
Stock intercooler
Stock psi
The engine is good though, no oil leaks, and had the 100K service done on it as well
My real question is.....what are the next steps to make horse power ??
FMIC??
MBC??
CPU??
How many psi can these rb25 take if i were to install a MBC??
https://www.sau.com.au/forums/topic/193687-newbier33-gtst-owner/
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
Thats a link to the RB25 Turbo Upgrade Thread, all the info you could possibly want on modification combinations and the power outputs they will provide!
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
