Lousy news guy did you stil have a 32 crank or had you updated the oil pump drive etc?
Believe the crank angle sensor from a 34 is different to a 32 and the end of the crank is physically different to suit
This being why there is one PowerFC for a 32/33 and a different one for the 34.
Sure someone could fill you in on the other differences,
or correct me if I is wrong.
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3475335
LOL i pulled it back from 5th to second by mistake from about 255kph. was well over 10k rpm showing
And to the old girls credit she is still running with no oil pressure, not to mention it had over 100,000kms on the engine anyway.
Thoughts were to remove this damaged engine and throw another stocky with the 2860 turbos in for the next race meeting while the damaged engine is at the rebuilders. i have about 2 weeks and not sure we can get the engine rebuilt in time, the builder has a few in front of me to complete.
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3476142
you are kind of right. GTRs don't have a crank angle sensor. they have a cam angle sensor. The camshafts are slightly different, and the cam angle sensor is different. Yes the crank is a little different too, but that has nothing to do with the sensor, it just has larger 'flats' to drive the oil pump gear (which presents no problem).
that is all I can think of off the top of my head.
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3476765
Yeah figured some one would correct me, my bad
and in my description where would ya put the balancer?
It must a been late in the night :P
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3477277
yep oil pump drive failure!
But very lucky, no damage to the crank must have been circulating some oil at least. All the bearings were in good condition a light polish on # 1 big eng gernal and back in she goes.
Not a nice job getting engine out for the first time with a pull type clutch
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3493110
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
