Hpi Dvd's & Xbox Games
Guest RedLineGTR
High Performance Imports DVD's & Xbox Games
For the HPI Dvd's I would like them to be sold as one set looking for $100 Straight For the Set of 4 Dvd's. Two of the dvds have two videos on them the other two and separate episodes. Might consider selling separately if all of them can be sold.
The Xbox Games will be sold as they are, in perfect condition case and dvd & manual for all games, some still have original receipt with them some don’t prices I am looking for each of them are.
Dead or Alive 3 - $20
Halo: Combat Evolved - $20
Project Gotham Racing - $20
Need For Speed Hot Pursuit 2 - $40
High Octane DVD's Number 2 & 3 For Sale. Looking For $20 Bucks Each.
Please Either PM Or Email
Looking For Melbourne Buyers
https://www.sau.com.au/forums/topic/19380-hpi-dvds-xbox-games/
Mate I am a guaranteed buyer for HPI v5 & 6 ~ man I really want to watch those for the R34 Project!!! :)
Rob ;) we can work out a price ok ? Please :)
I have some plastic polish and vouchers I can trade with ya :D
Seriously now, I WANT those dvd's!
I will PM, email and CALL you. lol.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
