  • Replies 66
Here's the joke I was too pissy to tell :dry:
Far away in the tropical waters of the Caribbean, two prawns were swimming around in the sea - one called Justin and the other called Christian. The prawns were constantly being harassed and threatened by sharks that patrolled the area. Finally one day Justin said to Christian, "I'm bored and frustrated at being a prawn, I wish I was a shark, then I wouldn't have any worries about being eaten..."
Just as Justin had his mind firmly on becoming a predator, a mysterious cod appears and says, "Your wish is granted", and lo and behold, Justin turned into a shark.
Horrified, Christian immediately swam away, afraid of being eaten by his old
mate.
Time went on (as it invariably does...) and Justin found himself becoming bored and lonely as a shark. All his old mates simply swam away whenever he
came close to them. Justin didn't realise that his new menacing appearance would be the cause of such a sad plight. While out swimming alone one day he sees the mysterious cod again and can't believe his luck.
Justin figured that the fish could change him back into a prawn. He begs the cod to change him back so, lo and behold, he is turned back into a
prawn. With tears of joy in his tiny little eyes, Justin swam back to his friends and bought them all a cocktail. (The punch line does not involve a
prawn cocktail - it's much worse). Looking around the gathering at the reef, he searched for his old pal. "Where's Christian?" he asked. "He's at
home, distraught that his best friend changed sides to the enemy and became a shark", came the reply.
Eager to put things right again and end the mutual pain and torture, he set off to Christian's house. As he opened the coral gate the memories came
flooding back. He banged on the door and shouted, "It's me, Justin, your old friend, come out and see me again."
"Christian replied "No way man, you'll eat me. You're a shark, the enemy and I'll not be tricked."
"Justin cried back "No, I'm not. That was the old me. I've changed."......................
"I've found Cod. I'm a prawn again, Christian"
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
