Joe! you're back!!
where are you stationed now?
big farkin yes to what?
no I am not back I am still in Korea... damm winter!!!
I'll be off to Beiruit in Lebanon as United Nation Peace keeping force Korean contigent :D
will be back in Perth next year some time :D
BTW Yes to Extractors :) hahahah
hey eug, just had a look at the design of those headers, they look mad as nice flow and high quality but i had one issue with them. The O2 sensor looks to me like it only reads from 2 of the outlets which would give it false readings and be a killer on your fuel and mabye rob some power off, it would be best for the sensor to mount in the collector just before the cat or to run muitiple sensors to get a correct reading, im not sure how much this affects the skylines, i just did a mates WRX turbo back exhaust and the O2 sensor mounted in a really crummy spot and his fuel consumption went down to like 280 kms so we had to move it and extend a few wires.
I know skylines arnt this tempremental with the O2 sensors but it might be something to look into if there is a big reported loss in fuel consumption, also in a high preformance application with tunning an after market ecu you wideband sensor probably wouldnt be as affective either
i had a look at that as well. you are correct, that is the best 'bolt out - bolt in' compromise method that they can fabricate.
ideally the gases in each pipe should be equal, it is on my to do list to suss that out. i run an SAFC2 with no dramas in fuel consumption.
yeh, i didnt think that it would have to much of an affect cause my mate shuan got some for his 32 on your first group buy and didnt mention an issue to me, just thought i'd mention it, wouldnt be to hard to re-fabricate a new mounting position, if anyone thinkin of doing it would be nice to see some before and after see if it makes any difference anywhere
please check the group buy thread guys.
i've spoken to one of the guys at partsco and the order has been given a priority.
fabrication begins monday! hopefully they'll be on their way prior to xmas, no promises.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
