hi
ive got a little issue with my car and have a feeling that my coil packs are on its way out soon
wondering if anyone around Dandenong or close to it have a spare set of coil packs working of course that can lend it to me for a few days just need to run it on my car to see if my are failing
its for a series 1 R33 skyline gtst
dont want to buy and waste money on something that isnt the problem
any help would be much appreciated
TRI
https://www.sau.com.au/forums/topic/194391-need-some-help/
take yours out and try and look for hairline cracks in them. You may not be able to see them, but if you can, wrap some electrical tape around them and put them back in. prob best to do it to all of them as it may be hard to see, but if its a misfire you are having, the tape should stop it. If it does you'll know its your packs then.
https://www.sau.com.au/forums/topic/194391-need-some-help/#findComment-3487332
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
