Model: 1999 Nissan Stagea RS FOUR S
Milage: 74,000 km
Transmission: 5 Speed Manual (factory)
Colour: Pearl White
Currently registered? 26 March 2009
Price: $24,500 $21,750
Contact: Phil: 0412 498 155 after hours or PM
2.5l Neo 6 cylinder Turbo (206kW, 362Nm)
5 speed 4WD
Auto Climate Control Air-Con
Power Steering
Power Windows
ABS
Dual Airbags
Factory 17" alloys
Nissan Floormats
Cargo blind & net
Xenon Headlights
Geniune Dolphin front bar and grill (These items are for sale separtely now)
Standard Front bar and grill fitted (will update photos soon)
260RS rear spoiler
HKS Silent Hi-Power cat-back exhaust (original available)
K&N panel filter
3 point immobiliser (Australian Standard)
Clarion MP3/WMA deck
Originally purchased from E&M at Five Dock, freshly imported, in March last year.
Still has warranty with them until March 2009.
Recently replaced rear wheel bearing, diff bearings renewed and crown wheel tooth lapped.
Oil & Filter change 20/01/08, Penzoil Synthetic 5W-40.
Very well presented, and great performance.
Fuel consumption around 10L/100kms, on 98 octane fuel.
Trades considered.
Edited by PhilTacular
https://www.sau.com.au/forums/topic/194456-1999-stagea-rs-four-s-sydney/
Like it a lot. Trade Gen 2 Liberty tt sedan, fresh conversion engine & auto only done 39000k body done 180000k (mainly country highway driving). + Mitsubishi rvr turbo 5 spd, 159000k standard. interested?
  • 1 month later...
  • 4 weeks later...
I'm running the car at WSID tomorrow (7/5/08), so if anyone would like to see it, come and find me.
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
