We'll I got my safc installed and tuned (on road - private no doubt) and cost me $200.
I went out to reinstall the unit again today, re route the wires etc and decide to check the settings incase I pull anything out. So away I got and my Safc neo shows the first 8 tuning points in 1000rpm increments. Im like :rofl:
So I've basically paid $200 for a tune that works but is not the full extent. Do you guys think its fair to ask the tuner to retune all 16 or 18 increments? I always figured that what your paying for. $200 to sit in my car and watch the air flow is great but you could have tuned all my points.
So because I'm rather angry and frustrated Id like to ask people what they think on the subject?
Also like to concur with people these settings.
Model Select - OFF
Sode Select - EASY
Car Select - Cyl: 6 Thr: /
Sensor Select - Type: Hotwire ???
Number: In: 1 Out 1
Calc In: 1 Out : 1 <-------- WTF are these and is this right?
Air Map
1000 2000 3000 4000 5000 6000 7000 8000
Hi Throttle +3 +2 -1 -2 -4 -5 -7 -8
Lo Throttle -3 -3 -3 -2 -2 -2 -2 -2
Throttle Point : Lo Throttle 5% Hi Throttle 45%
Do those settings seem right guys? People with S-afc Neos can you check what you guys had?
https://www.sau.com.au/forums/topic/194771-safc-tune/
Umm mate you got ripped hard.
I live in Tasmania, the land of incompetent expensive dyno tuners and my mate got his SAFC tuned for $100 and it looked a lot more extensive than that. He also has an R34 GTT!
He had 12 points being a SAFC II not NEO but this is basically what hes looked like.
1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000
Hi Throttle +3 +12 +15 +15 +8 +5 +5 +5 +5 +5 +5 +5
I can't remember low throttle but it was basically the same but leaner.
This obviously depends on the car, fuel ect.
I really dont know why he is making the car run richer.. that sounds really stupid because these cars run around 11AFR with stock tune which is way too rich.
He basically got just over 12AFR all the way except a little leaner before boost.
I would be requesting to see a graph of the AFRs before I accept a tune as finished.
Ummm.. calc in 1 out 1.... I dont think thats right I thought it was suppose to be in 4 out 4.. look in your SAFC manual.
Edited by Finny
https://www.sau.com.au/forums/topic/194771-safc-tune/#findComment-3490639
Hotwire refers to the factory 02 sensor.
nope, hotwire is the kind of afm it is.
DECIM8, maybe the turner was unaware of the "PRO" tuning mode with the 16 steps. the settings NUMBER IN 1 and OUT 1 is wrong, should be 4 and 4 (except GTR, 3 and 3). SENSOR CALC (calc in) is right, 1 and 1. or single and single
model select is off unless you have VVT and wish to use the neo to adjust the VVT (leave OFF)
and mode select you have it set to easy, or 8 step tune mode. select PRO in this menu and you get the 16 steps to tune.
https://www.sau.com.au/forums/topic/194771-safc-tune/#findComment-3490767
Just checked was on 4 .. my mistake ;)
Still does not excuse the whole 8 point fiasco
If I set it in pro mode and used the same figures as he has excluding the RPMs he missed in easy mode would the car run just the same as if in easy mode? until I go to another tuner and ask him to retune it - this time ill dyno it.
would that work?
Edited by DECIM8
https://www.sau.com.au/forums/topic/194771-safc-tune/#findComment-3490815
would that work?
i'd take it back and say they didn't do the tune properly.
make sure you write the tune down because i'm sure by swaping between easy and pro modes it clears the map, then check your throttle points and other settings aswell (just to be sure). then you can just re-enter the tune, but you will have to fill in the gaps, other wise you map will be up and down.
Edited by QWK32
https://www.sau.com.au/forums/topic/194771-safc-tune/#findComment-3490837
Alright Points taken, thanks a million guys - in particular QWK32. I'm going to get him to tune all 16 points if he will, not that hes prob done much of a good job. and then take it to get dyno touched up.
Lets hope he is up for it.
https://www.sau.com.au/forums/topic/194771-safc-tune/#findComment-3490923
Sorry guys I accidentily put + rather than -
thing is I have sen a fair few stock dyno graphs and ussually the stock tune richens to like 11:1 AFR after about 5000rpm which is way too rich, I think 12:1 would be much better thats why I am saying I can't see why he would be richening the mix at all..
When they did my mates R34 they said they want to run it a tad rich so that its nice and safe and they didn't add fuel to the map any where.
https://www.sau.com.au/forums/topic/194771-safc-tune/#findComment-3492044
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
