Item:
Xbox 360
Couple months
Condition:
Great
Price:
At the moment just looking to c how much there goin for so i know whether i should upgrade to something else or get rid of it
Macarthur Square
Contact:
Pm
Comments:
Dont know if i can do this here but am just seeing how much there worth so i know if i should upgrade it or not thanks heaps people
https://www.sau.com.au/forums/topic/194928-xbox/
i bought a new one with 2games (only one of the decent) plus 1 controller for $499 if that helps give you anindication. I reckon you could ask around $350, $300 if you don't have any games or controllers with it.
https://www.sau.com.au/forums/topic/194928-xbox/#findComment-3493095
Yeah i wanted to get rid of it all for 300 and i have two controllers and around 8 or 9 games at the moment i was offered alot less by eb games so i guess i am getting ripped of might have to sell it through tradingpost or something i guess thanks alot mate appreciate the help
https://www.sau.com.au/forums/topic/194928-xbox/#findComment-3493123
what games do you have? I mite buy some if you wanted to split them up?
https://www.sau.com.au/forums/topic/194928-xbox/#findComment-3493152
At the moment im just thinking of getting rid of it for 300 if i cant then ill just split the games up i have a big handful that i would include i just found the others i had
Scarface
call of duty
halo 3
fifa 2008
and a couple others when i get home ill check them out
https://www.sau.com.au/forums/topic/194928-xbox/#findComment-3493239
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
