  • Replies 232
****GROUP BUY CLOSED****
ok you all can thank me later by way of depositing $20 into my bank account :O
were are going ahead i will be paying for our tints on Monday and taking the list in and we can start booking in as of Tuesday
i only ask 1 further thing that the people that are already on the list on the front page PM me these details
Car: R33 4door
Rego Number: ABC 123
those that haven't paid yet but are on the list are fine to pay on the day of tint being applied
those that aren't on the list but have already registered interest in this thread will be added to the list
Thankyou all for your paitence
Trader Responses will be left for those that leave a response for me
EDIT
those not depositing money to me please still send me you car details or else the tinter wont know who the hell you are
Steve
oh 1 more thing alot of people havnt bothered to reply back to this thread after initial interest was put forth i will not be chasing you when i submit the list of people on the group buy if your not on it you wont be included
you will however be able to mention Skylines Australia for a 5-10% discount on tinting and installs
ok list being submitted after work please PM me your details if you havnt already
thank you to those that have already
from Tuesday 8th January 2008 you can start to ring auto perfection to book a time that suits you
for those that haven't paid i think i will say get in as soon as possible so the GB doesn't end
no idea will ask tonight when i go and pay for everyone
after ive paid i will make another post with phone number and name who to ring and what not if there are any other condiditons
Steve,
Is this a cash only job or will they except payment via card?
Cheers
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
