Anna what r u doin up so early is there gonna be a decent turn out?????
I dunno if it will be a decent turn out.... ive never gone to a meet at Krispy Maccas LOL!!
Im up ealry coz i start work early lol
Nurrh man..
work starts at 6 =(
AWWWWWWW!!!!!!!!!!!
  • Replies 237
Posted Images
How was the whore up peepz??? (anna&joey)
:D
LOL!!!! Joey is the BOMB!!! :stupid:
He is so cool.... i fell in love with his 34........... :D
i was so disappointed that YOU couldnt make it.... :P
So is there going to be a cruise anytime soon or have i missed it?
you missed last nights cruise!!
i dunno when the next one is?
make it next week! i'll have my car back by then
You can organise one for next week maybe?
Edited by Anna34
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
