Hey all,
Just wondering if anyone has had a genral respray... i.e. same colour and just cleaned the whole car up?
Im in Melb and have been quoted anywhere from $2,000 to $5,000+ for a same colour spray.
I have a black 32 and wouldnt mind going to a midnight purple or something like that.
Any ideas on cost or if anyone on the forums paints as a hobby...
Cheers,
https://www.sau.com.au/forums/topic/194992-resprays/
im getting my car re-sprayed over summer but doing all the disassemble-assemble work myself so the panel shop just needs to rub the car back and spray. ill be masking it up myself to.
the most expensive part of re-spraying a car is the labor. it takes time to prep the car which is what ill be doing and the spray part of the job, that includes repairing 2 areas and rubbing the whole car back, is only costing me about 1200.
SLYNE is getting his car done with me at the same time
https://www.sau.com.au/forums/topic/194992-resprays/#findComment-3495092
Wow 1200 is good. How long has it taken you to prep the car?
I have a friend who I can do the prep work with as he used to be a painter sadly he has no connections left ;)
Maybe I should do it that way...
I'm not wanting the engine bay to be sprayed as the colour will be the same if not very similar so no real gain there.
https://www.sau.com.au/forums/topic/194992-resprays/#findComment-3497655
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
