GREAT WORK BRYCEY HOW ABOUT SOME MORE BLIIINNNGGG DUDE,NISSAN PART NUMBER 26160-EWOOA,YOU WILL NEED TO CHANGE CONNECTOR`S ,SEE WRECKER`S post-36964-1199106427_thumb.jpgpost-36964-1199106816_thumb.jpgGREAT STUFF KEEP IT COMING,CHEER`S CHUCKIE.
  • Replies 105
Brycey, That is beautiful...
Makes me want to do mine....
Damn you!
:worship:
thanks man :) do it! :devil:
cheers for that info chuckie :) i just bought all new indicators for the car so i dont think ill be buying more any time soon :( they are very fancy-pants but! :D
  • 2 months later...
Can I ask why you chose all genuine over EastBear style kit? Simple bolt up for less?
Also, if you take your non-xenon headlights to a compliance agent, most are happy to swap them for xenon lights for a carton of beer, because then they dont have to hack up xenon ones for compliance, easier for them + beer :D
How easily did genuine parts bolt up ?
any bar suited for R34 GTR would have bolted up as nicely as genuine because its all obviously intended for the same body, but i chose genuine because i prefer the look, also having a plastic bar as opposed to fiberglass makes for a more sustainable body.. no doubt it would look great with any of the after market varieties but i was really keen on getting as many genuine parts as possible :ninja:
all parts were professionally fitted and fabricated by CCubed, but with the right knowledge and right parts it went together like a dream (as seen in the pictures), perfect lines, looks like factory fittment :happy:
the headlights that are installed are factory H4, so i think only after market xenon kits will fit (as opposed to factory xenon units), but i chucked in a really good set of globes recently, pretty happy with how they sit for the moment:)
the car is currently back at CCubed (in sydney) getting the V-spec diffuser installed along with a few other odd-n-ends (inner guards, bonnet strut etc), so i should have some new pictures this weekend :)
oh, also new numberplate's on the way CHE-35E :sick:
Nice one, Brycey.
Still waiting for you to rock up to a Thursday Coastie meet though. Xmetal Ian and Terminal have come along a few times now, and a few weeks back we had Duncan in his s1 and two M35s grace us with their presence at the Sydney meet-up point in Berowra.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
