Actually all you need to do is shock the steering coloumn. Take a bar of soft metal (aluminium), and a hammer, just give it a medium knock on the head, and that should loosen ur steering wheel, worked for me everytime.
Edited by KeeFy
  • 3 weeks later...
Ok so i bought one of the HKB boss kits from malz but it didnt come with the star tool to take off my stock steering wheel which leaves me stuck before i have even started.
so does anyone have one of the star tools that i can borrow?
i have this nice leather nismo wheel and its just sitting around in my room :(
alright so its a funny story but my aim was to get my old steering wheel off and get my new one on.
and i acieved just that.
so i needed these torx screws out, but they were bigger than any of the ones i had, PLUS they were security screws so they had the piece of metal in the centre of them. So first of all i got my drill and drilled out the center of the torx screw so i could try use a big screwdriver. Needless to say this didnt work but it was worth a try.
so then i decided to try and go through the front of the steering wheel by removing all the plastic coverings, so i could use multigrips to undo the torx screws from the side.
well i managed to get the torx screws out using the multigrips but the difficult part was removing the plastic cover from the front of the wheel.
now, i have nfi how the hell the front of the steering wheel comes off when the airbag wants to come out because i had to drill out 9 rivits and cut a few sections of plastic in order to reveal the airbag.
so i was now at the point of no return as i had esentially just used a drill to remove what wasnt meant to be removed.
nevermind the nismo wheel is better..
so i then had to get the air bag out of the way (which is pink by the way?? i always thought they were white)
now airbags are mighty tough as i descovered and had to resort to a pair of tin snips to get rid of it.
so i finally got it off and i was surprised that i was able to pull it of the steering column by just giving it a few hard knocks either side.
Then i managed to put the boss kit and steering wheel on with no problems. Apart from the fact i didnt put it on straight the first time as my wheels werent perfectly straight when i parked the car..
word of advice: DONT do what i did! be patient and either borrow or go buy a torx key as you will save A LOT of time and you will be able to use the airbag in the future if you feel the need.
:P:)
:P
Thats hilarious. Can't believe you went through all that. If I knew thats what you were going to do, I would have offered to come to your place, bring the key, and do it for you.
Oh well, at least you've got it one know lol
  • 1 month later...
lol...
Still haven't put my wheel on... I've only really been full time in Perth now for about 3 or so weeks...
I need to ask a n00bish question... Star key and allen key aren't the same thing are they???
intheglass, you're lucky that thing didn't go off in your face.. you will probably find the pink colour is due to a coating that will protect the airbag whent he explosive goes off..
You shouldn't fk with airbags people..
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
