Hks Evc Iv (in The Usa) Or Iii In Japan - Do You Use Learning Mode? What Does Offset Mean?
Hi,
My car came with a HKS IV (in American terms) I found the manual here:
http://www.hksusa.com/faq/?ID=1647
And my offset appears to be set to "86" when the setting is "Low".
I still don't understand what this means, does this mean that because the boost controller has not been through learning mode it overestimates boost a little and the offset corrects this?
Also, the "low" is set to 0.85, which is the stock boost?
And the "high" is set to 1.0, which I assume is 1 bar of boost at maximum.
What does the offset mean?
And do you use the learning mode?
Obviously I can't use learning mode until I get to a drag strip or similar, 2K RPM in 3rd gear to redline????
Also, if the battery is disconnected, does the boost controller store its settings in memory of some kind?
I *assume* it would but I'm not 100% sure.
Regards,
Gareth
P.S. no idea what turbo's I am running! I *assume* they're not completely stock but I don't know how to ID them.
i have the EVC III and i have set it up from scratch
yes the learning mode is abosolutely essential for stable boost control, if you havent dont this or dont think its been done then you should do it
it clears all the previous settings and learns your actuator step up rate so its handy to do
offset or probably duty usually refers to a open:closed rate in a ratio format - i think anyway
stock boost would depend on the car & actuator setup , i think for GTR it would be 12psi so around 0.80 bar
He's done a lot of modifications to the car and he likely has had it "learn" correctly. However the manual said something about the offset been 100 after it has been through learning mode, so maybe it was changed after that.
And the car's battery was dead for a few weeks, do the settings get stored somewhere so they don't rely on power? (Just been paranoid, I know it should :P).
Oops, 100 is the default setting, its probably been adjusted from there for low offset
I was just feeling a bit paranoid because I accidentally turned the dial on the controller without knowing what it would do.
If anyone is looking for the links to the manual look at the first post for the HKS USA manual's.
from memory the offset number you are talking about is only visible if the EVC is in manual mode
if the learn has been done properly and you arent in manual mode you cant see the duty
if i go into mode on mine i can set boost, boost warning, and boost scramable setting & duration
i cant see offset on mine, but i do recall seeing that when i skipped auto mode and went into manual mode
from memory to go between the modes you hold down mode for 5 seconds i think
and it cycles between EVC or manual mode check the III manual
its on my website paulr33.skylinesaustralia.com
Had a look and found the EVC 4 manual, or Japanese EVC 3.
Its the same manual on the HKS website so I think I've seen all the documentation available.
I checked through the various links on your website but didn't find it...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
