Hks Evc Iv (in The Usa) Or Iii In Japan - Do You Use Learning Mode? What Does Offset Mean?
Hi,
My car came with a HKS IV (in American terms) I found the manual here:
http://www.hksusa.com/faq/?ID=1647
And my offset appears to be set to "86" when the setting is "Low".
I still don't understand what this means, does this mean that because the boost controller has not been through learning mode it overestimates boost a little and the offset corrects this?
Also, the "low" is set to 0.85, which is the stock boost?
And the "high" is set to 1.0, which I assume is 1 bar of boost at maximum.
What does the offset mean?
And do you use the learning mode?
Obviously I can't use learning mode until I get to a drag strip or similar, 2K RPM in 3rd gear to redline????
Also, if the battery is disconnected, does the boost controller store its settings in memory of some kind?
I *assume* it would but I'm not 100% sure.
Regards,
Gareth
P.S. no idea what turbo's I am running! I *assume* they're not completely stock but I don't know how to ID them.
i have the EVC III and i have set it up from scratch
yes the learning mode is abosolutely essential for stable boost control, if you havent dont this or dont think its been done then you should do it
it clears all the previous settings and learns your actuator step up rate so its handy to do
offset or probably duty usually refers to a open:closed rate in a ratio format - i think anyway
stock boost would depend on the car & actuator setup , i think for GTR it would be 12psi so around 0.80 bar
He's done a lot of modifications to the car and he likely has had it "learn" correctly. However the manual said something about the offset been 100 after it has been through learning mode, so maybe it was changed after that.
And the car's battery was dead for a few weeks, do the settings get stored somewhere so they don't rely on power? (Just been paranoid, I know it should :P).
Oops, 100 is the default setting, its probably been adjusted from there for low offset
I was just feeling a bit paranoid because I accidentally turned the dial on the controller without knowing what it would do.
If anyone is looking for the links to the manual look at the first post for the HKS USA manual's.
from memory the offset number you are talking about is only visible if the EVC is in manual mode
if the learn has been done properly and you arent in manual mode you cant see the duty
if i go into mode on mine i can set boost, boost warning, and boost scramable setting & duration
i cant see offset on mine, but i do recall seeing that when i skipped auto mode and went into manual mode
from memory to go between the modes you hold down mode for 5 seconds i think
and it cycles between EVC or manual mode check the III manual
its on my website paulr33.skylinesaustralia.com
Had a look and found the EVC 4 manual, or Japanese EVC 3.
Its the same manual on the HKS website so I think I've seen all the documentation available.
I checked through the various links on your website but didn't find it...
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
