  • 1 month later...
people have always asked for an external gear changer with the proper slots instead of just up and down, and also a clutch.
i read that polyphony/sony were not interested in doing the whole 'proper gear setup' coz "each car in GT is different and you wouldn't be able to feel the difference.." EG some cars have 4 gears, some 6. it would be wierd.
BUT WHO CARES HEY?! i'm dying for a proper setup. to the point where i might have to try make one on my own or employ someone to or something. i'm sure the demand will be there because with GT5 being physically and graphically very life-like, a proper stearing mechanism should be on the cars (EDIT: i meant on the cards, not cars; but it workd both ways). I can only hope that they are developing one in secret and then... BAM, release it and stun people.
That's what I hope anyway
Edited by ALEX!
easy fixed...
Get a G25.
yeah get a g25, they are fairly cheep at dick smiths, got mine for under 300. been playing gtr 2 on it for weeks. tho to tell you the truth the h pattern shifter gets a bit too much and i use the paddles most of the time.
but all in all they are a great wheel
  • 3 weeks later...
thats some nice work man, :D unfortunately all my spare cash is going to be going on investing now but ill deff have to whip up something like that in the future.
that lil chair in yours looks like it could get uncomfortable after a while though :/ but nice all the same
thats some nice work man, :( unfortunately all my spare cash is going to be going on investing now but ill deff have to whip up something like that in the future.
that lil chair in yours looks like it could get uncomfortable after a while though :blush: but nice all the same
:nyaanyaa: It didn't actually cost that much to put together. The timber I found on a building site, small pieces of mdf was what I had left over from building my poker table (that's another story) and the chair was only about 30 bucks from Ikea. Just took a hacksaw to the legs :P
And it's surprisingly comfortable. Been doing some enduros lately and no complaints.
My mate has one he made of steel for his Forza wheel and utilises a VR commodore seat including the rails so you can adjust it for his tallness or my shortness.
He WILL be building one for me to use with my G25 on the PS3 :blush:
I'll try to remember to get some pics next time I'm round there.
  • 3 weeks later...
He WILL be building one for me to use with my G25 on the PS3 :cool:
Does the G25 work with the PS3?
Even the wireless functions?
  • 1 month later...
Im impressed bigslick. I want to build something like that but for the xbox wheel. How did you decide on the dimensions of everything?
Just took a few measurements while I was in the seated position I wanted, drew a few diagrams (yr8 tech studies came in handy for something) and did a few calcultions. Just in case it helps you to get started, the dimensions of mine are: length 1305mm, main frame width 575mm, main swingarm length 655mm, seat height from floor 250mm.
Mine is nothing special by any means. It does show you can easily buy basic stuff and have an OK setup.
G25
PS3 (GT5)
PC (GTR2)
(Note: the gear shift holder for my driving frame since arrived and has been connected, hence why the gearbox is "seperate" in this picture)
Edited by TommO
  • 2 months later...
  • 11 months later...
OK. So it's been......... WOW Almost a year!! :D Oh well, time flies.
Anyway, finally got around to upgrading the Playstation cockpit.
Bought a G25 (40% off at Harvey Norman) and car seat from Supercheap and knocked up some plans.
Me cutting out the side panels
The seat on it's custom base is detachable so it can be used as a normal lounge chair
View showing the gearshift mount box. And the flash showing up my blotchy paintwork! :)
Took the measurements from seating position in the GT-R.
Waaaaaay more comfortable and the G25 feels awesome ;)
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
