Ive got an annoying problem with my steering wheel turning to the left on its own..
i have searched the forum and the only thing i found is that it can be the wheel alignment, now im not to familiar with wat all those settings mean hoping sum1 can help me.
Now my steering rack had a leak in it so i had that replaced and a wheel alignment had been done.. and now the car pulls to the left no matter wat speed im going at wich is very anoying, whats more annoying is it pulls harder when i brake... wen i brake to a full stop the steering wheel can swing 45 degrees to the left on its own, so im constantly driving with my car pulling to the left, can some1 have a look at my allignment settings that i have attached and spot anything wrong cos i dont quiet understand it. Oh and i also had new tyres put on at the same time.
thanks
https://www.sau.com.au/forums/topic/195591-steering-wheel-turns-to-left/
who did it? IF i am reading this right, Your Right Castor is 4deg Greater than your left, And your RHF Camber is .49 lower than the left.
To compensate for the road, .25deg LESS positive caster on the right than the left is preferable, and .5Deg less Neg camber on the right than the left, with toe being equal. Same Rule applies for the rear with Camber, and equal 1mm toe in should help turn in.
You could take your car to GT-Suspension or Centreline if you are lazy, BUT I HIGHLY reccommend Traction Tyres in Rowville(10mins from the wellington rd exit of the monash) 9764 2811
I also recommend trackside in Kilsyth: Craig 9761 5557
-Ryan
Does your 33 have any non factory adjustable suspension arms?
Because your camber and castor are greatly different between your left and right wheels, but you cant adjust these settings with the factory components.
They have adjusted toe like they should (stock toe rods can be adjusted), but yeah...
Has your car been in a front end accident at any point? Seems weird the settings would be out by so much?
The pull is due to the caster difference. If you don't have aftermarket arms that are way out of adjustment, then you have a shot caster rod bush on one side atleast and should get them replaced.
as noted above, you cant adjust either caster or camber (on the front) from factory and they aren't that far out from factory.
To be honest even the dumbest alignment guy should have noticed a caster difference like that and pointed out that there is a problem.
And i disagree with ryan re the different settings side to side. From a performance point of view it is the wrong approach, from a tyre wear point of view it is great on a freeway where the old 3% crossfall mind set is still in force, but on most new local roads it isn't relevant anymore either.
I'm with BHDave, there is something wrong and they should have told you. Your left front toe was rooted before hand so they should have asket why
Caster is clearly stuffed, unless you have aftermarket arms you probably have a bent lower control arm. And your rear toe is so uneven it is dangerous - but it looks like they just measured it and didnt set it.
take the print out back, get them to explain why rear toe settings are what they are, and why your castor is so uneven a the front.
I would say the huge toe reading is from replcing the rack before the wheel alignment. The tyre wouldn't have lasted an hour with 23mm odd of toe.
The pull is coming from the huge difference in caster and also the difference in rear toe wouldn't be helping. I think you need to take it to someone who knows what the hell they are doing and start replacing parts as i think there may be something bent.
Edited by Potenza
Thanks for clearing it up dave! :P
Equal for handling, my alignment on my daily is a compromise between tyrewear and handling, and considering i drive on a lot of average roads, those differences are perfect for me.
-Ryan
The attached document with the steering settings is gobligook to me. I know I'm probably wrong, but have you checked your tyres :P? I only say this because a friend had both tyres on one side of his car let down, and then he couldn't figure out why his car was pulling to one side, silly bastard. The person also keyed a swastika on his roof.
So yeah... check your car for umm.. swastikas and flat tyres. Lol.
It was all done at the tyre factory.
The car hasnt been in an accident before, and there are no aftermarket parts.
Can u guys judge from a pic if the bushes r wrecked cos i took a pic of the left rod.
Umm so if it needs changing would it be more beneficial for me 2 just get aftermarket bushes or a set of rods.
and how do i go about fixing the rear toe does that require aftermarket parts also or just a decent alignment?
ill try getting my car down 2 traction tyres soon just have no money atm
Edited by YoungLine
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
