ok first of all i kno most people wont understand why i bought it 3 months ago and now im selling but its a genuine sale i just want to move back to a street car now so i need to let this go. ok......
1989 r32 skyline gts-t
SR20 motor ( out of a 2000 model s15 )
5 speed
211kw at the wheels
Apexi power FC computer + hand controller ( tuned at racepace in melbourne )
OS geiken twin plate clutch ( recently rebuilt )
TOMEI 256 cams
550cc injectors
HKS GT SS turbo ( less than 1000ks done )
N/A SR20 throtlle body
Big internal fuel pump
xforce manifold
rb25 airflow meter
GTR exhaust
Big TRUST FMIC
GReddy triple core radiator
KAZZ 2 way diff
HKS coil overs
camber adjustable
hicas lock bar
drift pineapples
SPARCO driver's seat
GTR interior
shift knob
turbo timer
sparco steering wheel
boost gauge
Racing pedals
Strut tower brace
Drift style handbrake
body kit is genuine BN Sport kit
evc 4 set to 1.2 bar
WORK miester 3 peice rims.. fronts 18'' by 10'' and rear 18'' by 11'' new tyres on the rims.. front 255/40 rear 275/40
Full wide kit 30mm rear and 25mm front.
have some shitty skid rims and jap quality 30mm spacers for them
the car is not complied but has all the import approval and everything. i was quoted about 6k to comply it if i did no work on it just gave it to them and got it back. the car is seriously sick ive never owned or known anyone who owns anything like it. turbo is pretty much on boost whenever you mash the throttle, makes 5psi at 1500rpm. ive had it dyno'd twice, one at aussie dyno and made 208 with boost spike and massive dodgey bleeder. after i got elec boost it made 211 with the turbo starting to run out of puff. ive olny taken it to lala once and that was a GRIP day. car went really well.
the only 1 problem is something has f**ked out in the gearbox we think the selector has f**ked up because i only have 1st 2nd 3rd and 4th no 5th or reverse. box feels really good apart from that. im sure its nothing major. my mechanic thinks the same. car lights 1st 2nd and 3rd no dramas but could do with some slightly skinnier tyres on the back for real good fun. i can put anyone who is interested in touch with the guy i bought it off who is also the guy who has done 90% of the work on the car for any more info.
price is $15,500 slightly neg at this stage. im in no hurry to sell what-so-ever so dont bother low balling me. car can be veiwed this weekend all glammed up at the christmas cruise. ill send it anywhere in aus with the buyer paying.
some adjustable arms and you would have a potentially competative car that looks sick and is different. paint is shmick as except for front bar which has a few little spider cracks from the drive back from melb. ok any more info let me know. cheers 0401178091
https://www.sau.com.au/forums/topic/195704-wide-sr-powered-32/
swap for our spare car? perfect sleeper with all the hard suspension work done... this is a wicked hills car.
http://www.skylinesaustralia.com/forums/S1...al-t197167.html
ive wanted this R32 since it landed a fe years back.
no help with the sale but seen this car first hand about 4 months ago and it is one orsome car. its pretty much what a jap biult car should be. this car would have so much potential with the sr20 to be either a grate drift car or an orsome full on track car.
^^ thats coz it is jap built... cheers mate. anyway still for sale. will be sliding on the 6th if no1 shows interest before then.
pics arnt flattering it looks much tougher in real life. paint is near on perfect and whoever did the bodywork did an awesome job. ill even chuck the dvd player back in it for the sale. cheers
Edited by boostd gem
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
