Alpine 12" Type X Subwoofer 3000W (SWX-1243D)
Condition: Near New
Comments: This has only been used for a total of 5 days. Currently in custom made box designed especially for the R34 boot as it doesn't offer much space. The box was professionally made by Platinum Car Audio and Interiors. It is in perfect working condition without any scratches or damages and it hasn't been cranked or used much. This is rated at 3000W and probably Alpines top of the range subwoofer. Receipts have been maintained. Currently out of the car because its at the mechanics.
Reason of Sale: Selling because my car had just broken down and need the money to fix up and also pay off bills.
Price: $650 For Sub and Box $600
$500 Without Box $450
(rrp: when i purchased $899, custom box $200)
Alpine Mono Power Amplifier (PDX-1.1000)
Condition: Near New
Comments: This has only been used for a total of 5 days. In perfect working condition without any scratches or damages. This is Alpines top of the range mono block amplifier. The plastic is still over the amplifier so its the closest thing to brand new. It was professionally installed by Platinum Car Audio and Interiors. Receipts have been maintained.
Price: $850 $800
(rrp: $1099)
Standard R34 GT-T Amber Front Indicators
Condition: Good
Comments: In perfect working condition. There are no scuff marks or damages to the lens or the housing. It is supplied with working bulbs.
Reason of Sale: Selling due to upgraded to nismo smoked indicators
Price: $50 $40 $30
Standard R34 GT-T Dump Pipe, Front Pipe and Catalytic Converter
Condition: Good
Comments: In good working condition. Only has been used on the car for 40,000kms. All heat shields still intact with nuts and bolts. Perfect to clear defects or to return back to standard.
Reason of Sale: Selling due to upgraded to turbo back exhaust.
Price: $100 $80
Standard R34 GT-T S1 Instrument Cluster
Condition: Good
Comments: In good working condition. No faults at all. The plastic cover is practically scratchless. Approximately 150,000km on the clock. NOTE: For manual trans only.
Reason of Sale: Upgraded to Nismo Cluster
Price: $150 $80 $50
I am located in the Hills Area
Pickups preferred for larger and delicate items such as amp and sub
Any further questions please PM
I can also be contacted on 0415 602 837
p1010001xm4.th.jpg p1010002ng0.th.jpg p1010003jw4.th.jpg p1010034ec6.th.jpg p1010038to5.th.jpg pdx11000lb2.th.jpg p1010007id5.th.jpg p1010010xf7.th.jpg
Edited by GMan
https://www.sau.com.au/forums/topic/195708-r34-standard-parts/
interested in the dump pipe etc...
applicable to a NA r34?
maybe a noob q...sorry...
nope because it bolts on straight onto the turbo..
u can take it anywas hahaha
haha right right...
im only on my red p's...so no use for it for a LONG time...
just looking for something to put in my NA r34...i wnna keep the dual tip...but change everything else without having the car run too lean...
cheers anyway..
shane
  • 4 weeks later...
  • 3 weeks later...
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
