Guest INASNT
Originally posted by JET-33
fkn oath, it scared the absolute crap out me, on half boost, and changin at like 6k....theres like 3-4k to go
no tacho goin in this, i will have to get a dash though so i have proper readings...
ash, the previous jet was only like a tyre length behind yours :) but this one will own u, in reverse :)
if u went in this car with dave gordo, you would understand, its rediculous that sumthin like that can b driven, as soon as its hits boost its ova....
yeh try 9 is a beast from sub zero, used to b known as 40RCD and was australias fastest 2.5 running low 10s, but then it was sold and the new guy put an rb30 bottem end in etc etc and went quicker
u farkin ***** jet :D
try09 is a 3.2 litre with rb30 block and rb26 head, intake with custom piston and rods, so i cant be called a gts-t anymore coz the only thing gts-t about it is that it is RWD but it uses metal rods as rear shocks so it would be a **** to drive on the road
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
