hI GUYS, my uncle and I have recently fitted an Apexi AVC-R to my r32 gts-t. In the etc. menu I have put the correct settings to what car it is etc...
Although my problem is that its boosting more than it should. I have set it to 0.7 bar (11psi) and through testing its reached a max of 0.83 bar and an average of 0.76 bar.
I believe that the duty cycle may need to be set properly. I know that the AVC-R is wired correctly because its showing correct stats on speed, revs, boost etc...
Maybe I have left something out although I can only think its the duty cycle at this point in time.
Thanks
Mark
https://www.sau.com.au/forums/topic/19606-please-help-with-setting-avc-r/
under boost set your desired boost and in duty cycle, step down one by one % until you reach your desired boost. if it doesn't change, then you've hooked up the solenoid wrong. remember to do the boosting in the same gear.
different gears give different boost levels (not by much tho) so use the gear learning function to keep your boost the same in each gear.
and don't get busted speeding when testing your boost level :)
i have done the sensor check and it seems to be right, although I have one question that maybe effecting it - instead of drilling a hole before the throttle body for one of the hoses for the solaniod valve a mechanic said that it would work the same from the actuator hose (the one ur ment to close off) so thats what we have done, also to avoid drilling a whole in the piping. Is that wrong?
thanks heaps for your help
:D
Which do you mean by actuator hose? Do you mean the one from the return from the BOV? In mine it was blocked off there, and taken from before the throttle side.
There should also be settings to adjust "sharpness" or basically reduce spiking, but i'm not fully familiar with the AVC-R functions so couldn't say definitely. I know in my ProfecB that setting can effect whether it hits an exact boost when u quickly put your foot to the floor or creep up 1-2psi over.
You probably should take it to somebody to specifically dyno tune after the install - as you will also need fuel/air adjustments as well to sort it all. The whole characteristics will have changed, even if you're running similar boost levels.
Hey Gordo, its the actuator hose that goes to the front of the turbo i believe, which is getting intake air anyway thats why the mechanic said it should work rather than drilling a hole in the intake before the throttle body. I feel completely lost after trying to set it for so long i think i give up. Im gonna give it a service next week and a dyno also :D
Do you think Ice will be able to look at it for me?
Do they know about the avc-r?
Is it better to get a service before the dyno or doesn't it matter?
Thanks Gordo
On mine at least, on the cooler piping before it goes into the throttle body there is a nipple (part of the HKS piping) - this goes via hose into the "in" side of my boost solenoid. From there the "out" side goes direct to the actuator.
Depending on how the AVC-R works, it may just need a t-piece into the existing intake->actuator line. Wait a tic.. will check the installation diagram for u.
i will post a pic tonight as i have a new shiny digicam *woot* picture is 1000 stupid words :(
Ice definitely would know about the AVC-R (or VMS, BMT or any other workshop probably) and probably installed 50 or more.. they can tell u what you are doing wrong. If you have time go down there and they'll probably tell u in 5 seconds. They can hook you up with a dyno tune as well.
Service will help if they clean or replace the plugs. New oil, and new fuel filter might make the engine rev a bit more smoothly too... so might be a good idea b4 the dyno.
cheers
I'm looking at the diagram right in front of me.. From what it sounds like, you've got the air line side of things connected up all fine. As long as you got your pressure sensor rigged between the fuel reg and the plenum all should be fine.
Sounds like something else is going on.. anyway, sounds like the BMT guys can sort it out for you.
Thanks heaps Gordo ur a great help mate!!!!
Thanks Jedcoyxiicut if got it ready to be seen by Excess Engineering as they aparently distribute all the apexi stuff, although I will contact you if all fails. Thanks heaps again mate!
Also could you tell me how much it would cost for a basic service and dyno tune?
Thanks again guys :P
Thanks heaps Dr Drift, I'll definetly be comming to u for dyno tunes and services and stuff. I will need a dyno very soon so i will give u a buzz, also thanks for offering to explain the cycles with me as Im very interested with the dyno stuff :D
Talk to you soon Mate
Mark
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
