Hey guys, this has nothing to do with Skylines but thought you might enjoy it.
It's a couple of years old but it's still pretty cool. I love the sound this thing makes and the acceleration is just phenominal.
Here's some of the specs:
The car is a Norma M20 Chassis with a 3 litre DOHC, 24V straight 6 BMW engine in it making 400hp, mated to a 6 speed sequential gearbox.
Max speed on the Bourgelais Village course (not sure if this is the actual one) in the French Hillclimb championship is 230kph.
http://forums.bimmerforums.com/forum/showthread.php?t=439195
https://www.sau.com.au/forums/topic/196407-vid-from-a-french-hillclimb/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
