I will vouch for the condition of this car...the engine has had too easy a life at the hands of this guy...someone buy it and drive it properly please...lolz...
LOL!!! yeah you should know how well i treated this car eh :down:
I never drove it to its full potential :banana:
https://www.sau.com.au/forums/topic/196590-sold/#findComment-3554790
washed and maintained at arguably the best detailer in the southern hemisphere (Damian @ Final Inspection) nice choice! :D You on the FI forums??
for white, got some nice gloss happening there in some of those shots... hard to get from white. What wax is/was it wearing?
that's an impressive list of mods, sounds like a screamer of a car. Good luck
https://www.sau.com.au/forums/topic/196590-sold/#findComment-3556489
I have to agree with you Gohan :worship:. Damian is just the right man to go to. I'm there at least once a week to get my car washed.
Yes i'm on the FI forums too :devil:
The car has recently been through a STAGE 3 detail by Final Inspection. Not too sure of the wax they use but it sure does the job.
https://www.sau.com.au/forums/topic/196590-sold/#findComment-3559171
Not to trouble you or anything but would you be able to get a picture from the back ?
Cheers
Hahaha! are you so interested in the ass shots eh?
unfortunately i don't have any at the moment. But it looks just like any stock R34s without the NISSAN badge and 25 GT-T badge. ;) No damages at all.
And the best part now is that it's only $25,500!!!
https://www.sau.com.au/forums/topic/196590-sold/#findComment-3572680
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
