Not sure if it will help anyone but there I just picked up 4 bottles of the stuff from repco in Campbelltown at the princely sum of $10 a bottle (500ml).
Pretty sure it was a pricing error but there were a few bottles left so if any1 needs it nows the time to go :nyaanyaa:
Edited by GriMo
https://www.sau.com.au/forums/topic/196634-cheap-rbf600/
Hey GriMo can you go back and buy every bottle? then sell them on here for 20 I will take 2 or 3 and I'm sure others need it to.
Its the best brake fluid I've used and for $20 for a full flush every skyline owner should do it. the difference with new fluid and properly bled brakes is amazing
https://www.sau.com.au/forums/topic/196634-cheap-rbf600/#findComment-3521265
Cant get out there till tomorrow but ill see if they have anymore. When i left they only had a few bottles left.
https://www.sau.com.au/forums/topic/196634-cheap-rbf600/#findComment-3523644
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
