ok so here's the thing. starting to need to do the whole oil problem thing in my gtr. and i'm not going to ask what i do cause i searched for all that stuff.
but
is it an engine out job to put the trust sump extension on. can i get away without running the external feed from the back of the head if i do the sump and the restrictor in the head? is it an engine out job for the external feed? i would imagine head off (need to happen anyway)
just trying to organise what to do.
cheers, stephen
https://www.sau.com.au/forums/topic/197054-32-gtr-oil-control/
yeah you need to tap the back of the head for the external return. and if you tap the sump for the other you really should have it off too.
yes it is engine out to change the sump. (well it may be possible but you would need to take the subframe off, support the motor in the engine bay and take the flywheel off to get at the rear main seal bolts)
i would like to do that. but i don't really have the cash lying around for it. well i could scrounge it up but it's for other fun things.
could possible be pretty quick to blow. there is another gtr in the mechanic that i use. blew his motor i am guessing partly because of oil issues and partly because he thought it was ok to run 25psi through a standard motor. and frequently swing it to redline on a cold motor.
oh well looks like i might be putting a bit more money aside. taking the motor out and doing the sump+restrictor+external oil feed. and of course a minor port+polish and a set of cams while the head's off :banana:
