Hi all after some advice.
I have $1100 to spend on my r33 gtst series 1.
What would be the best value next thing to go for i have as follows already done.
Kakimoto exhaust
HKS pod filter
Walbro fuel pump
Mongoose alarm
all stereo components as i want.
Lowered king springs
Roh holotype R 17" mags
Brand new tyres
Brand new exedy heavy duty clutch
100000 klm service just been done.
custom front bar
custom rear wing
windows tinted.
Ebc fitted set at 7 psi (usually drive with daughter in car so no need for big power)
After some ideas to do next.
everything else that isnt listed above is standard
any fuel air management options in that price range?
Thanks in advance for any advice
https://www.sau.com.au/forums/topic/197130-what-to-do/
Dump and front pipe and large Cat (if not included in the "kakimoto exhaust")
or
SAFC NEO would fit in the under $1100 catagory installed and tuned.
or
Some new Shock absorbers to replace the dead old ones which have further been killed by the lowered springs.
Edited by GTST
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3525639
or
or
What he said if your looking at more power.
Also look into some steel braided brake lines, new fluid and good pads (makes the brakes fell new again), or perhaps some new suspension bushes/shock/springs/swaybars to get it driving really nice.
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3525647
Thanks for suggestions guys should of mentioned all suspension and brake components are only a couple of months old, so all good in that department.
where in bris would be good to supply and fit an safc and tune?
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3526009
If you have thoughts of putting a FMIC on, do it before you do the SAFC, you'll only have to retune afterwards otherwise.
Also, boost it up before you get it tuned (Boost to a happy level, around 10PSi should be plenty)
Then tune it.
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3527451
Stock intercooler is a restrictive piece of junk that doesn't really cool anything down (Good at heat soaking)
So really, no, I wouldn't be calling it safe.
With exhaust, FMIC, boost and tune, the car will be TOTALLY different for you.
FMIC kit is like $300 - $400
Fit yourself.
Get a boost controller, (Those $22 ones are great!)
Then get a second hand SAFC2 and tune it.
All for under $1100 if you do stuff yourself (Dyno it to tune it though)
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3528012
FMIC for $400 involves cuttong a hole in the chassis, trimming the fan blades, cutting the front bar and it's support.
$150 R34 GTT side mounted stock intercooler is bigger than the R33 one in each direction, yet is a straight swap (bit tight but still straight swap).
it has been proven number of times to be good for cooling and flow for around 220rwkw.
your stock turbo will not do any more than that anyway.
$150.
remove some hose clamps, remove some bolts, remove old intercooker, then reverse the steps with new intercooler.
ALSO, SAFC will be tuned on a dyno.
that is when I would increase the boost. not before.
better safe than sorry.
strap the car on.
increase boost to 10psi, dyno run, get result.
then the tuner goes and makes the adjustments and runs it again, then same step over and over to find the best compromise.
expect around 190-200kw
Then post a thread on here about your result so everyone can take out there online penises and compare. :w00t:
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3528140
LOL @ online penises.
OK now to find an r34 intercooler?
also how much should i be paying to fit and tune the safc 2. One workshop which i wont name has quoted $150 to fit it then around $600 to tune on dyno and wants car for 2 days?
https://www.sau.com.au/forums/topic/197130-what-to-do/#findComment-3528468
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
