Hi guys,
i found this one one of the discount websites im registered with and thought some of you guys may like in on this deal
me and Bunny33 have gone halves in a set, there are 29 sets left mine is being AAE posted i will post up picks when i get it :(
Details
Our Price : $139.95
Average Retail : $189.00
YOU SAVE : 26%
Features:
* Massive 7 km range
* 1 Watt transmit power
* 40 Licence free channels
* 38 Privacy codes (CTCSS)
* Range extender in duplex mode
* Channel scan
* Keypad lock
* Keypad tones
* Backlit display
* Battery level indicator
* Low battery alert (audible)
* Roger beep
* Channel busy indicator
* Time-out timer
* Call tones
* Accessories: 1 twin desktop charger, 2 rechargeable batteries, 1 AC adaptor, 2 replaceable coloured faceplates
* 2 bonus microphones
Specifications:
* Two-Way Radio Dimensions: (H) 17cm x (W) 6cm x (D) 3cm
* Brand: Motorola
* Model: T5509R
>>Product Link<<
https://www.sau.com.au/forums/topic/197395-walkie-talkies/
Details
Our Price : $139.95
YOU SAVE : 26%
Features:
* Channel scan
* Keypad lock
* Keypad tones
* Backlit display
* Roger beep
* Time-out timer
* Call tones
>>Product Link<<
Hi Steve, I don't want to take anything away from the quality of these units but a 1 watt radio wont give you 7km range in Adelaide you'll need a 5 watt in perfect condictions to come close. We use radios regularly on the road and find that the way they are rated is at night in the country with no buildings or trees around.
Having said that, if you need something for communication between 2 cars driving together, 1 watt is definitley the way to go because it won't chew up battery life and won't get too hot.
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3529473
i was going to get a pair of the Uniden ones for $50 but i thought even that was expensive for something i might only use once a month...This looks like a great unit and deal though for sum1 who decent quality...
Maybe we should organize a group buy for some :banana:
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3529507
Steve I want a set tell me whats needed for you to obtain these for me.
if you want put $155 in my account and i will order today will get here on monday if you do ring me and let me know so i can put order in ASAP 0421932750
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3530190
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
