finally sent my car in for the rebuild but there is alot of unanswered questions about the 3.0L conversion.
as far as i know it hasnt been done to the r34 but alot of success for previous models.
if there really is to much stuffing around ill drop the turbo size and stick with the 2.5.
i was hoping if anyone could put in some feedback as to wat to expect and wat to prepare for.
heres a quick rundown of wats already in the works.
gt35
plenum
throttle body
injectors
clutch
manifold
dump/front pipes
cams
rods
pistons
the motor is being pulled out atm so we still checking its state, i thought id take this time to do a bit of research whether to really go 3.0L or just to leave it at 2.5
any help would be appreciated guys.
Edited by R34NRG
https://www.sau.com.au/forums/topic/197470-r34-gtt-30l/
Help for what?
There is a RB30 sticky thread, has been for years, it has all the information.
Just because your using a R34 body, means nothing. Go read the information
Honestly mate, im going to remove your thread starting rights if you keep up the starting of threads without no researching.
Cheers.
https://www.sau.com.au/forums/topic/197470-r34-gtt-30l/#findComment-3530278
Guest
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
