Hey guys, I'm putting all my Automatic tranny gear up for sale as I'm going to be converting to manual over the Christmas break. Everything is still fitted to my car at the moment, and potential buyers in Melbourne are more than welcome to come for a drive to feel how it shifts etc.
I'm not going to separate anything, only selling as a package.
1. B&M Pro Ratchet Shifter, Including everything needed to install to a R33.
http://www.bmracing.com/index.php?id=produ...at=2&pid=21
2. B&M oil Cooler with all hoses and fittings. Also has brackets made to mount it where the stock smic is situated.
http://www.bmracing.com/index.php?id=produ...at=&pid=282
3. M.V Automatics Stage 2 shift kit.
http://www.skylinesaustralia.com/forums/Au...mp;hl=shift+kit
4. M.V Automatics manual shift computer AKA black box
Once everything is installed you basically have a Manualised-Automatic, meaning the car will only change up/down gears when you ratchet shift.
The shift kit has been on my car for about 15,000K's, and the other parts for about 5,000K's. The tranny hasn't started to show any kinds of premature wear, nor have the shifts changed since i first installed it. My car makes ~220rwkw and everything seems to be taking the power fine, no slipping at all.
There are a few cosmetic scuffs on the casing of the shifter but nothing to be concerned about.
$550 for the lot.
Can contact through PM or call/sms 0422 816 780 My names Shane.
https://www.sau.com.au/forums/topic/197653-r33-automatic-upgrade-kit/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
