R32 Gts-t Type-M Front Bar (Black) $130
R32 Gts-t Factory Wheels 16x6.5 $250
R32 GTR Factory Seat (Pair) $650
R32 GTR V-Spec II Bonnet (White) $475
R33 Gts-t Factory Exhaust cat back $150
R33 Gts-t Factory Air box with Air Intake $120
R33 GTR Factory Wheels 17x9 $1400
R33 GTR Driver Side Guard (White) $475
R33 Series 1 Factory Grill $35
R33 Series 1 Factory Front Bar (2 to Choose) $50
R33 Series 2 Factory Front Bar no indiactor (Black) $130
R33 GTR Factory Front Bar no indicator and low lip (Silver) $220
R33 GTR Aftermarket Front Bar (White) $350
R33 Gts-t Aftermarket Front Bar (White) $180
R33 Gts-t Rear Diff $180
R33 Gts-t Factory Intercooler $65
R33 Gts-t Series 2 1997 Model Interior (Front, Rear Seats & Door Trims) $450
R33 Gts-t Tail Shaft $150
R33 GTR Turbo done 48000km $600
R34 GTR V-Spec II Turbo BRAND NEW $1600
Momo Steering Wheels with Boss Kit suit R32 $150
Enkei RP-02 16x7 suit 5x114.3PCD pull out from R32 Gts-t $400
BLITZ BOV for R33 Gts-t with pipe $150
I selling all these parts on behalf of my brother he is a ture Skyline Fans when he in Australia!
All the parts locate in Brisbane South Side interest in any of them please PM me with your contact number so I call talk to you!!
Edited by cool_banana
Have u any better pics of the above?
If they are any good we'll talk about a deal eh lol :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
