ALL ITEMS LOCATED IN CAIRNS
CONTACT ME THROUGH PM
Item: Braided line - approx 5m (14mm fits 5/8 fittings)
Price: $120 (including frieght) or $30 for a metre
Item: 4" Silicon Pipe (approx 120mm)
Price: $50 (incude frieght)
Item: Standard R33 GTS-t Airbox (not including intake snorkle)
Price: $30 + frieght
Item: Standard R33 GTS-t Exhaust (dump pipe back)
Price: $400 + Freight
Item: Standard R33 GTS-t Intake Plenum (bottom section only, top sold)
Item: Standard R33 GTS-t Throttle Body ( not including TPS)
Price: $75 + Freight
Item: Standard R33 GTS-t Side Mount Intercooler
Price: $60 + frieght
I ALSO HAVE MORE STANDARD R33 RB25DET PARTS AVAILABLE.... I WILL ADD MORE TO THIS PAGE WHEN I GET TIME
https://www.sau.com.au/forums/topic/197847-various-items-for-sale/
  • 3 weeks later...
  • 4 weeks later...
  • 4 months later...
  • 5 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
