Hi all,
David got his hands on a new kit with slim ballast (digital ballest) smaller and more powerful 42W
Avail in H1,H7,H11,9005,9007 and Single Beam DH4,DH7
Price is 150$ per kit refer to pic below plz contact David from Plus M Imports
0433 684523
P.S Mention SAU to get the discount otherwise these kits sell for 399$
Can i swap with the old stock ? :P
yeah you can if you want to :P you'll have to pay the Differeance
Will swap only one of the kits bro otherwise id have to swap everyones BPI kit for this BPI one.. sorry
Ok guys im SOLD out of H1 in the 42W but still have the H! in the 35W , will get more stock within 2 - 3 weeks and post up new stock and prices
Vish, where is this shop? I'd like to go there on the weekend. Thanks.
i have got and installed and look sweet
might post some pics up of my 33 with em
and big thanks to Vish for the help with the install
Edited by Damit
ah no worries Damian ! glad to help out ! must say it looks a lot better after the headlights were poilished !
Hey sexi Jez... hunni havent seen you in ages ! lol bro i know in the R32's theres 2 sets you can get for the projector style , one is H1 , the other one is a H3C or they refer to it as a 9007/9005 system i would like to take one buld out and have a look just to make sure
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
