  • Replies 78
Does the phrase half cut mongrel enter anyone elses mind. I have no idea why people would basterdise a good car by adding a heap of fibreglass and bog to it. I hate any of those half this half that cars except the r34 front on a stagea as it seems to be the only conversion with any merrit just my opnion .
just my opnion
exactly...
I was thinking of doing this conversion myself until xmas time and rego sent me broke, but we'll see in the new year...
Its not as expensive (apparently) as youd think, ive had a word with the guys at Uras who've done a few of these conversions, and (once again, apparently) theres no real crazy modifications needed.
All that is needed for this to work is:
R33/34 conversion fenders - $300-400 roughly
R34 headlights - $5-600 plus
R34 bonnet - around $2-300 or go aftermarket which is around $500
R34 front bar - $1-200 or once again aftermarket $3-400
Budget around $2000 which should be enough. And if you can source the front panels which are the same colour as your car you are laughing!
Those conversion fenders are popping up all over the place now, so they are not that hard to come by. The only thing thats hard to find ive found is the R34 headlights, and if you can source them they are generally quite expensive...
If your going to do it, good luck and take many a picture!!!
:banana:
Edited by Musky
people do this because apart from the front nose all r34 look shit house. the rear is 10 metres off the ground and porpoise like a bitch. they are big fat bricks with no incling of aerodynamics.
atleast here u still have the nice flowing lines of a r33 with the sharp bulbous nose of the 34.
best of both worlds
u see how it looks low and sharp. where as if he bought a 34 is would look shit
u r a f**king idiot if u think that an r33 has better aerodynamics then an r34 then ur just a retard!!!!!!!
Saw something weird as today - a s15 body with a R34 head but with WRX doors...pretty hot....
Was this in the West again? :devil: That's some weird conversion.
Come on now... No need for that. We all know R32 has the best aerodynamics. :blink:
hhhmmmm. yea that explains why r34's have a severe porpoising problem (!)
r33's squat lower and are far more stable.
im just saying this from seeing hill climbs, talking to drivers
and driving an r33 and an r34.
i think the r33 has best handling and stability.
i have only had a short squirt in a r32 gtst, so i cant really comment on a r32, all i can say is if u have a r32 gtst your gay. soo guttless
Edited by r33cruiser
Cant really comment on drivability... but I think R33 looks much tougher.
"r33's squat lower and are far more stable.
im just saying this from seeing hill climbs, talking to drivers"
:D:devil:
sorry but i can't find the smiley face with the WTF sign.
:laughing-smiley-014: :laughing-smiley-014:
You bring a smile to my face at the end of a shitty day .
Someone find me the WTF sign please LOL!
Yeah, good to see that you're laughing... :(
But sorry to say, a R33 GTR does look tougher than the R34.... but then the R35 owns all... totally up to the eye of the beholder. :P
I have to agree with the R34 guys, the 34 looks better. The back end is pretty tall, noticed on a SAU cruise, but I'd still love one. That said, I think the R33/4 hybrid looks awesome, and is something different at least. Would like to see pics of one without the wide guards though.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
