Hey,
CAS on my r33 gtst is currently set at 10 degrees (retarded because stock ecu was advancing too much). I've got myself a power fc which I'm about to install and drive around with for a few weeks before i get it dyno tuned.
I figure before I fit the pfc i should return the CAS back to 15 (default?). is this easy with just the basic tools? how do I get the right angle? does the CAS click with each degree or do I need to pull out the old protractor? clockwise or anticlockwise?
searched but couldnt find much on specifically adjusting the CAS.
thanks in advance :)
https://www.sau.com.au/forums/topic/198255-cas-adjust/
LOL! yeah get the protractor out and take some pics and show us how its done, that would be educational for all of us =)
hhahahaaa just kiddin mate, you have to get a timing light and set the timing by using the timing marks on the harmonic balancer on the bottom of the engine.
Probly take it to a mechanic would be the best bet for you, oh and btw it does not click.
https://www.sau.com.au/forums/topic/198255-cas-adjust/#findComment-3540721
I did read a few mentions of using a timing light, but I assumed that was if you were unsure of the default CAS setting.
If i know that the default CAS is 15 degrees, can't I just set it at 15? or is the angle not evident from the outside?
https://www.sau.com.au/forums/topic/198255-cas-adjust/#findComment-3540764
Yeah its not evident from telling the timing on the CAS. only when using a timing light on the harmonic balancer when you tell the timing then you move the CAS to correct the timing.
https://www.sau.com.au/forums/topic/198255-cas-adjust/#findComment-3540846
probly better off waiting untill you put the power FC in and get your tuner to lock the timing. (its a term used for setting the timing on CAS to be the same on the ECU)
so just to clarify guilt toy, i do this BEFORE fitting the power fc?
https://www.sau.com.au/forums/topic/198255-cas-adjust/#findComment-3541552
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
