This happened also on my 84 mitsubishi starion... foot to the floor, revs increase then juust as turbo spools up a rattle sound emerges...
no change in power or engine noise, just this slight rattle sound??? and the sound then dissapears as the revs increase.
i've got no idea??
anyone else had this?? or even better, know how to fix it?
thanks heaps for any help!!!!!!
a metallic rattle? probably the motor pinging. Do you have standard computer? is your fuel system in good condition?
yeh i guess its sort of a metallic sounding rattle...
Standard computer..
No misfiring, so i'm guessing the fuel systems ok..
The only mods so far have been, 3in cat back/ r32 actuator (10psi)/ grounded solanoid wire..
What is pinging?
pinging is when the cylinder is pre-igniting ie before the spark is due - it will damage the piston since the cylinder fires while the piston is still heading up. Caused by a cylinder running to lean (ie not enough fuel) or too hot, or both.
its just that it can often occur as the car reaches max boost. Make sure your fuel pump is working OK first if its standard computer since it runs pretty rich on its own.
when you say max boost do you mean at like top end revs? cause thats the thing, it only makes the noise coming onto boost, as it reaches top end doesn't make the sound.. its strange, like something is loose but i don't know..
Detonating? i dunno...
It sounds like a spray can rattle, like somethins loose, but only when boost starts to come on, then disapears as revs increase...
but it doesn't happen all the time when i give it, only every now and then...
i dunno? just thought someone may of had same experience..?
Had exactly the same sound. Main fault was the fuel pump trying to run with only ~10v and the diaphram on the fuel pressure regulator torn. Ran rich at idle, but where it needed it most, right in the meat of the midrange, as the turbos were starting to boogie it would rattle like a handful of ballbearings in a big milo tin, after this point it would settle down.
Very easy to spot on a dyno run, if you haven't yet it is real cheap insurance.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
