R34GTt Manual Gear Surround
VGC
$100ono
Melbourne
PM me if interested
This one is SOLD ............... But I also have another if anyone is interested in as new condition $160ono
Edited by wrxxy
https://www.sau.com.au/forums/topic/198364-r34gtt-manual-gear-surround/
  • 1 month later...
  • 4 months later...
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
