as stated in topic.
how many rwk's would a r33 gtst need to make in order to be on par, or slightly better than a holden vy ss with 300 rwk?
i ask this because the 1/4 mile calcs dont quite add up.
would like some real answers
(both cars with equal suspension mods and tyres. no variables )
cheers guys :thumbsup:
300rwkw VY ? or 300kw HSV factory version?
If its the factory 300kw motor version then you need about 175rwkw (in the real world*) to keep up maybe beat it by a nose, both cars driven reasonably well.
300rwkw VY is probably around 230rwkw-ish. Depends on a few other things as well like gearing.
* by real world I mean that the car is making this power on the road as well as the dyno, bonnet 'down' dyno numbers.
i dont think a 175rwkw would be a 300kw vy ss
standard quarter times for my bosses senator was 13.7 last time i looked it up which is the 298kw version
skyline with 175 which is basically an exhaust and about 10psi i think would lose
not by much tho
this is a good thread to keep on the go.
I have a R33 gts rb25det conversion with low diff ratio, FMIC, pod 3" exaust BOV etc n i was wondering if i'd beat my miss's brother's VZ SSV V8 ute which just has basic exaust mods...? wat we think?
