I let my girlfriend drive my car and she may have messed with my apexi turbo timer. Now my electrics is f**ked. Basically the turbo timer now wont even turn on, the clock is not working my aircon/air has the dash display but does not vent air and my immobileser keeps turning on after i have started the car and i have to unlock it every 5 mins while driving. My car has shut down a few times to whilst driving, it made a ticking noise like when your battery is flat too. Could this be battery related cause i have let it go flat by leaving the lights on twice this week but i seems fine now. or maybe could it be a fuse, but that doesn't explain the immobilser
https://www.sau.com.au/forums/topic/198786-big-electric-problems-need-help/
Don't blame the missus, your battery is gone for due to battery being over drained.
Also immobilizers do funny things at low voltage.
Battery might be salvagable, but most likely will die in the arse when you least want it too.
Before you buy a new battery check that your alternator is charging properly.
It should read at least 14volts when the engine is running.
When my alt. was dying the warning light didn't come on but I had weird problems with almost everything electrical and my alarm /immobiliser was the most sensitive to the low voltage.
You killed a battery TWICE IN ONE WEEK, and the problems you are having are the fault of your gf driving your car?
Your battery will not be a happy camper. Get a new battery.
Yes i left the lights on twice in one week. This is the first time it ever happened to me and it was twice in one week. Key word in my first post " she may have messed my car up" i am not blaming anyone i am just stating what happened so i can have other opinions.
Just turned on car to move it somehwere else, started fine then shut down a few metres down. Then started it up fine again, same thing happened it shut off. Now it wont even start. WTF. Anyone know for sure this is the battery
its a r33 gtst s2. Its definately not the battery. We tested it and its fine. It has to be the turbo timer. Apexi pen one There settings on there for a/f, o2, batt, and timer. I was never shown how to use it by Xspeed (guys couldnt give a shit there) but i figured not to f**k with anything but the timer. I know my gf fiddled with it and she didnt know how to change the timer but changed something. I wasnt there at the time so i cant be sure but i know its not the battery.
do a google search on ya brand of timer there are instructions on how to set it .
keep prssing the button till it reads voltage that will tell if ya battery is ok or starting to fail
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
