  • 4 weeks later...
rsx84 and outlawskyline
my wheels are still the 4X114.3 PCD, the wheels are Concept Trilogy's in 17X7. they are a +38 offset, bought from tempe tyres.
some guy tells me they are chrome dipped in USA or something?
i am actually thinking of selling these, considering my car does not get driven anymore (involved in accident still waiting insurance pay out).
was thinking of advertising in the for sale section, but i previously tried to post a cd player for sale and it wouldn't let me post, kept saying VB message shit
i also have a pair of simmons V5 for my car that i may consider selling if i can get the wheels i want
https://www.sau.com.au/forums/topic/19881-r30-kw/#findComment-479117
Guest outlawskyline
Yeah, they look alright, if thats ur car. Im not really after any wheels as such, but u shouldnt have any trouble sellin em as they hard to get, mine r actually 17 x 8s, its a tight sqeeze under there and is constantly scrubbin on the rear drivers side, i should get my guards rolled, cause nobody likes the sound of their rubber grindin away unnecessarily!!!!!
https://www.sau.com.au/forums/topic/19881-r30-kw/#findComment-480570
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
