Just a query..
Are the 33 & 34 auto's pretty much the same strength & physical measurements ?
I have been toying with the idea of slotting a tiptronic R34 auto into my 33, purely for the tiptronic option. But have no clue whether the R34 boxes are any stronger or weaker than my current R33 auto..
Any takers on this one ? Any rumours anyones heard, or has anyone here already done it & had some results they can throw my way.
please keep the "just get a manual" comments out of this thread, its my cash & my car - so get over it. ;)
Cheers guys.
https://www.sau.com.au/forums/topic/198911-r33-vs-r34-autos/
Don't know for certain about strength differences, but rumours I've heard is that the 34 box can take more.
Fitting shouldn't be a problem.
You will lose a gear though (4 speed on the 34 box, 5 speed on the 33 box). I believe the reason behind this has to do with strengthing of the belts etc. Perhaps somebody can clarify that though.
There are so any variations of these nissan boxes its hard to know which is stronger. The r33 comes with either the re4r01a (4 speed) or the re5r01a (5 speed) and the r34's ive seen are the re4r01a but with tiptronic control. The re5r01a's are longer as they have a longer rear extension housing with a extra gear and also have a larger dia output shaft by 2 splines. The all have the same size input shaft but some have an extra speed sensor at the front near the bellhousing which means they have a course spline half way along the small input shaft that the pickup reads from which would reduce the strength somewhat. As far as i know they all use the same single band but there are some variation with clutch sizes and spline counts inside. Ive just finsihed building a couple of re4r01a using the strongest bits from each model of the re4r01a using a SR20det bellhousing, r33 main case with a subaru 2.7 1st gear, the largest size aftermarket clutches and steels, carbon band, s6 rx7 output shaft and rear extension housing (same dia as the re5r01a), the largest planetary sets (cryo treated), all shafts either cryo treated or remade in en26, full manual valve body assembly with a transbrake and billet servo.
Yeah a friend of mine has an R34 GTT, its a 4sp triptronic. He has pretty much killed the box with only stock power and 100,000km. Now it takes for ever to shift gears and you pretty much have to mail it an invite to down gear when you use the triptronic controller.
The main reason the stocky boxes dont last is that they run low line pressures especially on gear changes. They do this so they have smooth changes but it wears out the clutch packs. By modifying the valve bodies upping the line pressure makes them shift hard with less slip. This can extend the life of these boxes but you really need to start off with one that has good clutch packs before modifying.
  • Like 1
Ive just finsihed building a re4r01a using a SR20det bellhousing,
R33 main case with a subaru 2.7 1st gear,
carbon band,
S6 rx7 output shaft and rear extension housing (same dia as the re5r01a),
:) GOD-DAMN DUDE !! :(
Sounds like you've invested a little more time than a simple weekend sussing out your options & putting the right combo together - thats luto !!
What sort of cooler set-up are you going to pair with that combo ? Stand-alone air cooled, or combo of stock plus an added front mounted air cooler
The r33 comes with either the re4r01a (4 speed) or the re5r01a (5 speed) and the r34's ive seen are the re4r01a but with tiptronic control..
I had no idea a 5 speed was optioned, well there's my new thing i learned for the day. But if theres a good chance the 4 speed is slightly stronger, i'm sticking with it..
So from what i've read, sounds like the tiptronic is essentially the same box as what i have now, only it has an electronic gear selector added. I already assume i'd need the box's computer to go with the 34's tiptronic function.. And a manual valvebody conversion is already on the check list waiting to be ticked off.
This info is good guys, cheers for this. If anyone else has anything more to add then don't be shy.
It's good for what i'm trying to find out & also good for future searches from other members.
The re4r01a's are going behind sr20det's, one is a 200b and the other a 1600. Both of these cars are drag only with the cooler being mounted at the rear of the car with dedicated fans as there is no room to mount at the front. I am also currently doing a stagea auto but swaping the re4r01a main box for the re4r03a main box with full drag internals and a mating shaft to suit the stagea transfer case.
Don't do it.
The R34 RE4R01A and the one from the R33 are mechanically pretty much the same but the valvebodies and the electronics are totally different. Unless you are really good with car wiring this will be a nightmare. The R34 TCU is a single unit with the ECU so getting them to talk to a stock R33 ECU would certainly be a challenge.
You can manualise the R33 box if you want. Talk to Mike at MV Automatics in Adelaide as he is without a doubt the preeminent expert in this area. Last I spoke to him the shifts were made with an after market shifter like a B&M but if it can be all done electronically now then I don't see why you couldn't buy a tiptronic steering wheel off someone like me who has done a manual conversion and wire up the buttons.
Thats pretty much the end result i was chasing.. An MV valve-bodied/manualised auto with electronic shift function via either steering wheel buttons - or maybe even paddle shift for wank value :(
  • 3 months later...
any chance you could let me know the cost, and how much power this will take. as i,ve just upgraded to 360hp (268kw) @ hubs. and am looking to go to nearly 500hp (372kw) next year.
thanks bruce.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
