JBL - mono amplifier 460 watts . cs300.1
PIONEER - 1000 watt subwoofer - Housed in a ported enclosure .
more or less 3 - 4 months old , still come with boxes . these items are in superb condition.item is located in sydney - PICKUP ONLY. please PM me for questions. i have payed over $500 for the lot , so i am going to be reasonable with the price and i am seeking $350 firm for the lot . i will accept trades for r33 parts , such as BOV's , posibly aftermarket front bars - otherwise cash sale prefered. thanks.
https://www.sau.com.au/forums/topic/199069-fspioneer-sub-and-jbl-mono-amp/
Hmm...
Really want that amp.. im in sydney and i can pick it up in the coming week. Would you be interested to separate?
anyone want a sub so we can double team?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
