hey guy, i just did a major service on my r33 and all was running just wonderful. i have had her tuned since putting on the new turbo (HKSgtrs). along with this i did the plugs to. i put in ngk BKR5ES-11. now i have been driving the car around for a week or so since being tuned and having the new plugs a nd turbo on and itr was tarting perfect, like almost immediatly...
but now i have to cranck her over for about 10-20 secs and put my foot down on the throttle. once she is strated she runs a little rough and then once it warms a little then it all calms down.
any ideas why this may have happened....???
this happned before when i first had my powerfc tuned and the tuner put new plugs in....
im thinking this may be plug related...???
https://www.sau.com.au/forums/topic/199143-trouble-starting-car/
i use bkr7e
never ever heard of them spark plugs...
if u have a turbo timer and u let it idle for 5 mins or so with the combination of wrong spark plug, could be fouling your plugs thus creating all them symptoms...
Next time ur at home and u try start the car n its doing that whole 10-20 sec thing, take one spark plug out and see if its fouled (covered in black dust looking stuff)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
