Its the biggest Drum and Bass show ever to hit Adelaide!!! Though my Opinion is abit biased being an investor :thumbsup:
And its pretty dam cheap considering the line-up!!!!!!!!!!!!!!!!!!!
and yeah the Talent should be good on and off the stage, Dnb shows seem to get a decent following of lovely ladies
Edited by benny_blanco
https://www.sau.com.au/forums/topic/199255-summer-break/#findComment-3554281
more details Lee
Hey Andz! Tomorrow, starts at 12 and goes till 10pm, will be in Rymill Park in the city, best D'N'B line up ever.
Im old school with dnb and haven't been out in ages and wont be able to go out much anymore, so im looking forward to this one.
What you think?
https://www.sau.com.au/forums/topic/199255-summer-break/#findComment-3554302
too true Benny!
Adelaide has a monster of a following for DnB...
A lot of the big DJs & acts like Andy C, LTJ, Pendulum, all say that Adelaide is one of their favourite places to play on the globe!
I'm in the same boat Lee; hardly venture out into town into the clubs and rage on like i used to. but come outdoor festivals > BDO, FMF, and this: Bring it on!!!!$#$@!*@
:thumbsup:
Edited by MSPEC33
https://www.sau.com.au/forums/topic/199255-summer-break/#findComment-3554338
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
